Ga door naar hoofdinhoud
The Xiaomi Redmi Note 3 smartphone was released by Xiaomi in March 2016. It includes a non-removable 4050 mAh battery and supports up to 256 GB of removable storage.
3.5mm headphone jack is short-circuited
Hi
I was testing my own FM transmitter with my xiaomi redmi note3 pro via 3.5mm audio jack as a MP3 player
I connected the headphone wire to my circuit with a 10uF capacitor and 10k resistor, and suddenly the mobile was restarted and, as a short circuit occurred, the mobile was warmed up , I could not play music , I could not record the sound and there was no contact, and the battery was quickly discharged.
what should i do ? is there any sound card (Like PC's) to change it? What kind of flaw can be
Is dit een goede vraag?
Score 5
1 Opmerking
ranslate/66371/en
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@alisystem Your connection shorted things out on the motherboard. “Is there any sound card (Like PC's) to change it? “ no, there is not. It is all part of the motherboard. You will have to try and find somebody that has the schematic for your phone and can check the audio circuitry for you. This is not going to be an easy fix. The only one I have available would be for a Redmi 3Z Note3 and I would have to see your motherboard to ensure it would work for your phone. Post some good images of your motherboard with your question so we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 2
I plugged aux cable in my ipod touch 6 gn and connect to my car it switch of by it self and then I connected my iphone 6 it also switched of and turned back on buy my ipod just showing black screen after that and if I connect it to my mac it saying in recovery mode but not updating to its on black screen can u tell what happened how can i fix it
Voeg je antwoord toe
ALi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 4,202
