Ga door naar hoofdinhoud
De Tiida(Versa) hatchback en de Tiida Latio sedan debuteerden in 2004 in Japan, en in geselecteerde Europese landen in 2007.
Reverse camera RCA cable
Hi There,
I have panasonic cn-hds625d and need to get a RCA cable for the rear view camera. Please advise what is that slot type called and where it is available. This car is currently in Newzealad and it is an Japan Import car
Sorry. Missed to update the image... adding it now.. Please also where i can get these cables in Newzealand.
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
'''++ttsenkumar kumar++''' not quite sure which slot you are talking about. I suppose you are referring to the rear camera slot. You can always post some images of what you are looking for with your question. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that. That is most likely proprietary and without a proper schematic it will be extremely difficult to source it. I do believe that there is a rear camera kit for your navigation model Check for something like YESFX999101
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks Mate... Just added the picture
door
Voeg je antwoord toe
ttsenkumar kumar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 689
