Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 water damage with VCC_MAIN short
Hi all!!
I have an iPhone 6 that took a bath in the toilet. Before it turns forever into a “$@$*!&” phone, I started to repair it but now I have few problems that maybe some good users can give some help.
Here are the steps I did so far:
1 - I have disassembled the main board and took all the EMI shields out. The damage is clear and I could see a lot of corrosion marks in some main capacitors.
2 - I started cleaning the hole board with a good and proper solution and everything looks fine now.
3 - Then I have tested the VCC_MAIN and it was short. I tested with a good power supply with the current limit set to 1.5amps and it was obviously short because the power supply reaches immediately the limited current.
4 - I took a look on the VCC_MAIN line and I found some dead and short capacitors which I have removed already.
Q1 - Now I have no short anymore but the VCC_MAIN resistance is between 20 and 30 ohm. Is this a normal value? Before it was 0 ohm = short.
5 - after that I tried to power the board again and the current dropped to 0.6amps, which obviously means that there's still a problem elsewhere.
6 - I have found that the U1501 was heating (no other IC was getting hot) by dropping some flux over it, even with those 0.6amps.
7 - then I have followed all the capacitors in the power lines supplied by that IC and I have found some more shorts which I have also removed, but still I am having a short somewhere and I dont know where.
Q2 - should I remove the IC U1501 and test the VCC lines before I end with no caps?
Q3 - After removing that IC the VCC_MAIN should give a higher resistance value?
What would the next steps?
Thank you very much and if you could help me I would really appreciate.
Is dit een goede vraag?
1 Opmerking
You might want to bring it to a local phone and computer company. Or you can ask Apple for help.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
VCC_MAIN at 20-30 Ohms is too low. You should be reading approx. 0.350V in Diode Mode. You still have a partial short that you will need to find. Even if one cap on a line is short, they will all look short. Finding a VCC_MAIN short can be a pian in the you know what.
It may be another cap but if U1501 was in bad shape, I would remove it to see if that removes the short. Otherwise, You will have to remove stuff one by one until you find it.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Challenge accepted. thank you.
I'll update next week.
door
Please update us as you move through the process.
door
Hi!
After removing U1501 I have VCC_MAIN resistance at around 480 Ohms and 0.331V in diode mode.
Are those good readings?
Will it boot without this IC?
As far as I know, U1501 is an IC for powering the display ...
Thank you :)
door
Voeg je antwoord toe
Gomes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 347
