Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4680 Vragen Bekijk alle
"Settings" for backlight repair?
I have done several motherboard repairs, but always have problem when i repair the backlight.
What I have heard you can change both BL Ic, Diod and coil to make sure all parts are good.
Question is what is a safe working temperature for removing them and then install new ones? On the ones i have tried I always have problem to remove the coil.
In what order do you install them? Are some of the components more "scared" for heat?
All tips will be appreciated.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
you could always try this way https://www.youtube.com/watch?v=_3pZPuYV...
door
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
1 Antwoord
Gekozen oplossing
The coils are difficult to remove without damaging them as they are made with some form of soft graphite (or something). They may also be glued in place prior to being soldered in places so they don't float around during the soldering process.
If you do a full replacement, what some call a windshield wipe repair, then I would apply the same temperature as usual ( I use 380C at low airflow on a Hakko 810) but make sure to heat sink the CPU and generally point your airflow away from it. You will probably want to pry the coil once the colder is flowing in that area so you don't leave heat on their longer than necessary. Practice on some dead boards.
For the rebuild, I would definitely start with the smallest components (C1513 & D1501 make sure R0412 is still there) first as you will have lots of "elbow room" to work without the big ones in place. Then it's really a matter of preference but I would keep the IC for last. The other components will help guide you for it's proper alignment and you don't heat it unnecessarily either. Keep in mind you are next to the CPU so heat transfer must be limited to what is essential.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Johan M zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 61
