Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
20 Vragen Bekijk alle
iPhone wont lock screen while making call
Hi
I had a busted iphone 3GS display and I followed the great guide on ifixit.
Now the iphone is working great expect for one important thing.
When I make a call, the display wont “lock”, So when I put the Iphone up to my ear, my cheek touches the iphone activating the speaker or punching numbers.
I guess that the iphone should have a sensor, that detects the position when a call is made, and putting the display in a locked mode.
How can I fix this?
Thank you very much.
Best regards
Dennis
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
It is definitely the #3 ribbon. If reseating doesnt work, then replace. Careful not to damage the connector. The ribbons are pretty fragile to bends and kinks. Avoid this.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
thank you. I am going to try that. I must have damaged the connector. Will let you know. Have a niec day.
door
Dennis if you damaged the connector let me know, I replace them all the time.
door
Hi Hector. Great news. I replaced the #3 ribbon and now the phone is working fine! Thanks a lot! have a nice day.
door
Awesome Dennis!
door
Het nuttigste antwoord
You may Need to change ur proximity and light sensor the one u bought may have been defected.
Score 1
1 Opmerking:
try reseating connector no.3 or cleaning the flex and connection first before replacing it.
door
What about in a Iphone 4? I have Same issue.
1 Opmerking:
this question is 2 years old. I recommend that you ask your own question and give as much detail as possible. "Me too" does not work unless you tell us what you did, what happened and what you have tried. Use this link to get to the question section. http://www.ifixit.com/Answers/Ask/
door
Voeg je antwoord toe
Dennis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 3,132
