Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De LG Stylo 3 Plus is een Android-smartphone die in 2017 door T-Mobile werd uitgebracht. Hij beschikt over een 5,7-inch HD-scherm, 32 GB opslagruimte en draait op het Android 7-besturingssysteem.
How to delete or disable multitasking
How do I turn multitasking off on my LG Style 3? It constantly opens and closes when it wants to. I can't find where to disable it.
Is dit een goede vraag?
Score 1
2 opmerkingen
I get that. It doesn't help. The phone keeps trying to multitask on its own. I am trying to find a way to disable it all together.
door Deel
I have been trying and trying to get it to start in safe mode but I never get the option. I will keep trying. However I did a reset and it was still doing that before I added ant apps.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi @chriskg ,
This link may be of some help to you.
Update (03/08/2018)
Hi @chriskg ,
Since you tried a reset (I assume that you mean a factory reset?) and it is still happening the only thing now is to check if there is a system update available. If there is try it and see if it resolves the problem.
If there is not or if there is and it still doesn't help, how old is the phone? Judging by the reviews it is a fairly recent model. Check your purchase receipt for a date and if the phone is less than 12 months old consult the manufacturer's warranty statement as to what you have to do to make a claim for a manufacturer's warranty repair or replacement.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Hi @chriskg ,
Try starting the phone in safe mode and see if the problem still occurs.
Is it always the same app + another that starts the multi task?
door Deel
Voeg je antwoord toe
Christine Grosch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 656
