Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Sony XBR-65X850D is een 65-inch LCD Ultra HD-tv met led-achtergrondverlichting en een 2160p-resolutie. Uitgebracht in 2016. Modelnummer: XBR-65X850D.
Replacement screen for tv
Good afternoon . Where can I find a replacement screen. A remote got throw to it. Stupid mistake.ive taken the broke off and the white screenis not damaged. Please point me in the right direction. I spent a fortune on this tv. Thank you again
Is dit een goede vraag?
Score 3
21 opmerkingen
I have the same issue except I have a 75 inch. Does anyone have a replacement screen for sony bravia xbr75x850f?
door Deel
I need a screen as well for a XBR75X850C sony TV
door Deel
I need a screen for a Sony Bravia 75 inch
X900F
door Deel
Sony XBR85X900F screen replacement required. Please assist. Thanks.
door Deel
i also need a screen tv has never been used out of the box that way xrb75x850c
door Deel
16 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
@websterd panels that size are pretty much impossible to get. If you do find one it will be more than the TV. You can try and do an online search based on the label of the panel, not the TV. Of course you can also try to find your make and model TV that is broken other than the panel, harvest the panel from that one. This is going to be a tough job to find.
Was dit antwoord nuttig?
Score 5
1 Opmerking:
I need Sony Bravia 75 inches screen display how can we get it
door Deel
Same thing happened to me. I had to buy a new TV. Even Sony told me it was around 1000$ just for the screen not the
https://www.tvserviceparts.com/TV-Video-...
Voeg je antwoord toe
Webb davis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 42
Altijd: 29,164
