Ga door naar hoofdinhoud
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
166 Vragen Bekijk alle
not taking a charge or powering on.
My PSVita will not take a charge or power on I bought it from a pawn shop a while back and it would not do anything and they would not take it back what might be the problem and how would I fix it.
Is dit een goede vraag?
Score 1
1 Opmerking:
So I will get a new battery as soon as I get the money what is it like $15
door
Voeg een opmerking toe
2 Antwoorden
@fatedengram this can be an issue with the charger, the charging port and/or the battery. Use a multimeter and check your charger to make sure that it has the proper voltage output (5V). If that is okay check the power port and change the battery while you are at it. Use these guides PlayStation Vita to work on it.
Was dit antwoord nuttig?
4 opmerkingen:
I will need to buy a multimeter then to test them.
door
i tested the battery and the charger the battery im getting 2.82 and i tested the charger connected to the motherboard and im getting.14 with the wall outet .02 with the usb plugged itno my laptop if i tested correcctly.
door
@fatedengram "the battery im getting 2.82" start with a new battery. Not sure where you tested for the voltage on your port but either one is to low.
door
I disconnected the battery from the motherboard and tested the connector
door
Try opening it and unplug battery and plug back in then charge it. Sometimes that can fix. If slim model the android style charging cables are junk and often go bad. So it maybe your charger.
Voeg je antwoord toe
Jake Romine zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 1,629
