Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Singer EZ-Stitch kettingsteeknaaimachine is bedoeld om beginners te helpen hun eigen leuke en creatieve projecten te maken. Hij kan worden gebruikt voor het in elkaar zetten van knutselwerkjes, kleding, kussens, accessoires en meer.
Thread gets stuck in machine
My singer machine has thread that gets tangled in the machine. I have gotten it out following the book, but it happens again every time I try to sew. I can’t use it at all. I bought it at least 10 years ago & didn’t use it for the first couple years, then we moved. I tried using it & had that problem immediately. I asked my sewing teacher & she told me it would cost more than the machine is worth to fix it. I can’t afford to buy a new one. I picked it up for like $115 at Target. Not the highest model. I also followed instructions for threading.
I have a different model than chosen. It’s a much better machine than this.
Is dit een goede vraag?
3 opmerkingen
Its not the machine pictured. I have a full size machine.
door Deel
@magecat any idea what model your machine is?
door Deel
It’s a much better machine than the one pictured. It has several stitches. There is a bobbin beneath the plate, none on top.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Is yours a chain stitch machine like the one pictured, or does it have a bobbin beneath the plate as well as a bobbin in the top?
I wrote up all I know about sewing machines at https://wiki.restarters.net/Sewing_machi... - perhaps the tension is wrong, or the needle is bent, or the timing is out.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
ladycerridwyn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,767
