Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
iPhone 4 clock losing time
I was asked today about an iPhone 4 (A1332) which seems to have a problem with the real time clock. Now and then it loses maybe half an hour and then recovers the correct time a day or two later. Text messages don't seem to come through when it's in that state.
I suspect it could be a problem with the RTC chip (probably not a separate chip but a function integrated into the processor or one of the peripherals) in which case it's probably not fixable.
Probably the only chance of a fix would be if it's a software problem, so I suggested backing up her data and doing a factory reset. But if the flash memory is getting tired a complete reflash of the kernel would be more likely to do the trick. Not sure how to do that. Ideas? Or other suggestions?
Regards - Philip
Is dit een goede vraag?
1 Opmerking
@pleriche this "Text messages don't seem to come through when it's in that state" sounds more like a connection issue. Check the antenna cables etc. If not check with a new Sim Card and see if that will help.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Real time clock is a waste of time to diagnose on a old phone. Better yet to get another 2nd hand iPhone 4 rather than try to fix the problem as it would be a lot cheaper and less time spent.
You could try restoring the phone via iTunes but you would need to do a backup first. I doubt it'll help though.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Philip Le Riche zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 170
