Logic board replacement problem
I’m trying to repair a late 2009 21,5in imac of a coworker. The computer freezed in the loading screen and refused to work. It was tested by a local Apple distributor which diagnosed video failure but refused to replace logic board as the computer was obsolete. As the computer doesn’t boot, I cannot verify any other information on the configuration.
I ordered a replacement logic board through Amazon market place and, after disassembling the computer per the iGixit disassembly guide, I found two connectors missing from the replacement board when compared with the old one. One is labeled MXM TEMP and the other is a large ribbon connector placed under the GPU? heatsink. The labels are etched on the board but the connectors are missing. I was wondering if this may be a problem eith the replacement board or this being different from the one installed in the computer. Any ideas? Thanks!
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Missing items in red
Is dit een goede vraag?
Voeg een opmerking toe
