Ga door naar hoofdinhoud
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Vragen Bekijk alle
How can I fix a DS Lite that does not maintain its top case position?
I would like to repair my old DS Lite that felt on the ground many years ago. It still works but now it has a hole which reveals its hinge. The problem is that when I open the DS Lite to play its top case won't stay in position, infact I can't hear any "crack" that usually it does when the top part locks to stay in that specific position.
Which parts have I to buy to fix it?
Here are some images:
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi @dadeaka ,
It looks like the upper case will have to be replaced.
Here is a link to the ifixit Nintendo DS Lite Upper Case Replacement guide, which should be of some help.
Here is a link to a supplier of parts for the device. (scroll to the bottom to find upper case parts). It is not a recommendation to use them. It is shown to give an idea of the cost of the part.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Good luck finding a screwdriver that small! Lol
door
Hi,
I might have the last laugh
Tools required:
Phillips #00 Screwdriver
Tri-point Y1 Screwdriver
door
Can I just ask, when the OP says the top case doesn't stay in position, do you mean it is really floppy? My DS has no resistance at all to keep the screen in place. I just wondered if replacing the upper case will resolve this issue too? Thanks
door
Nintendo will fix it for free. The thread is a bit old, but you should call Nintendo support and ask.
https://www.engadget.com/2006/07/21/nint...
Voeg je antwoord toe
Dade Aka zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 2,562
