Ga door naar hoofdinhoud
De LG G4 werd begin juni 2015 in de VS uitgebracht, waarbij zoals altijd de focus lag op high-end specificaties en een verfijnd modegevoel dat de smartphone laat opvallen in de premium markt. Elke versie van de telefoon heeft een ander modelnummer, afhankelijk van of deze door een provider wordt verkocht of simlockvrij is (VS of internationaal). Sommige LG G4-toestellen staan bekend om problemen met bootloops.
Phone not accepting Sim Card
So my old LG G4 (H815 Factory Unlocked) isn't playing ball with my Boyfriends 3 Sim. The phone is confirmed Unlocked and I've been able to use my GiffGaff sim in the phone which further confirms it's unlocked. However it refuses to accept a 3 sim (Both my new 3 Sim; his and one from the store)
I've tried factory resetting the phone a number of times, rebooting, opening it up and inspecting the prongs. Nothing; any advice?
I've also fiddled with APN settings and LTE/GSM settings.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
While this is likely a hardware issue with the cellular radio, try another SIM card. It doesn't need to work, so use a dead SIM that's been deactivated or an expired T-Mobile SIM. The other option is to buy a prepaid SIM card kit from Net10 or Tracfone since the phone isn't carrier locked.
If you continue having issues, there's a problem with the cellular radio or SIM slot. If you're comfortable with board level repair, you can try to troubleshoot further. f you are not, then you're going to need a new motherboard.
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
See, I failed to mention that it did detect the sim once, it had a data value but no connection. I think a motherboard replacement may be in order though.
door
That could mean the SIM is inactive. If you know with 100% certainty it's active then it might be the board.
door
Sim is 100% active; it's been working in another phone. Sounds like a mainboard issue
door
Sim card not working other phone simcard is working
door
Voeg je antwoord toe
Finlay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 26
Altijd: 7,507
