Ga door naar hoofdinhoud
Reparatie-informatie voor de Brother MFC-J6920DW draadloze multifunctionele inkjetprinter. Modelnummer: MFC-J6920DW. Voor het eerst beschikbaar op Amazon in september 2012.
Horizontal lines out of alignment.
When i print, horizontal line are a different height every 2"
Is dit een goede vraag?
2 opmerkingen
Hello I’ve done this many times since the problem suddenly appeared - some of the nine example squares are identical so it is hard to do! The fault remains in that the printed image is in slightly offset stripes which, as I print music, is frustrating. Any ideas for a global fix? Cheers!!
door
I have been fighting this issue for months….I finally gave up and flushed the Brother printer and bought a new printer from HP. It was TOOOOOO FRUSTRATING tyring to fix with NO LUCK and NO HELP from Brother.
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi @kdglover ,
Try a print alignment and check if this resolves the problem.
Here is a link. Scroll down to the section Checking the print alignment
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Kenny Glover zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 33
Altijd: 5,420
