Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Signet-serie was in de jaren 50 de topreeks van Amerikaanse 35mm-camera's van Kodak. Het is een van de slechts twee Signet-modellen met een meetzoeker en het enige model dat niet grotendeels van plastic is gemaakt.
double superimposed rangefinder patches problem
When view through viewfinder on kodak signet 35 , the rangefinder patch appear from 2 triangle 70% superimposed but slightly shifted horizontally on left side.I could not discern what would cause one triangle to split into two, though I suspect it's a a misalignment. What area should I be inspecting?.I wait for yours ideas.Thanks.
Is dit een goede vraag?
Score 1
1 Opmerking
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Your beamsplitter got mis-aligned. Review this IFIXIT guide: Kodak Signet 35 Beamsplitter vervangen. There should be a couple of small setscrews which has some glue on in to prevent it from shifting. One is to adjust the parallax (up & down) the other the infinity set.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
where could I buy a new one beam splitter ,because the coating of beam splitter does not exist and when view through viewfinder the triangle from the rangefinder is not longer visible , and i try using a piece of blank 35mm color negative that has been processed which I put behind the beam splitter, and followed these procedures the triangle of beam splitter is visible , but appears as double triangle, probable first triangle is a reflection of 35mm colour negative film procesed , and the second triangle is reflection of beamsplitter glass.What do you think.Thanks
door
This is such an old camera parts will be difficult to find. Maybe you can find a second non-working camera to steal the part from to fix yours.
door
Thank you very much
door
Voeg je antwoord toe
Florentin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 43
Altijd: 831
