Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Canon's derde versie van hun point-and-shoot cameradesign met lange lens. Oorspronkelijk uitgebracht in februari 2006.
LCD screen cracked. Replacement process?
The screen on my camera is cracked.
The screen will not come on at all right now.
I would like to replace it.
I found the blow-up diagrams but is there a correct process?
Do I also need to replace the Back Light Unit?
Thank you in advance for your help!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
@nanaburt yes there is and all you have to do follow it in sequence as outlined in this document S3-Disassembly.pdf
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Thank You oldturkey03. I have the diagrams, Can I start at the point of taking the LCD cover off (after removing the battery) or do I have to remove the screen at the hinge before taking the cover apart?
door Deel
... also ... are there any precautions on where I should NOT touch as I remove the PBC Assembly as I need to re-use the current one if possible.
door Deel
@nanaburt this does look complex but at this point I'd follow the individual steps as they are outlined. Stay away from the flash cpacitor since it does pack a punch. You should always discharge that one before working on a camera. I do try to not touch all over the pcb but there is only a small chance to either shorten things out or cause damage due to static electricity.
door Deel
Voeg je antwoord toe
Gale zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 618
