Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
Dead Laptop with long orange then quick green flashing ac adapter
So I have a dead mbp. New battery coming Friday. Just bought a new ac charger. Tried the pram and smc resets...nothing. Tried with and without old battery doing all of the above. I'm assuming it's a bad logic board but I'll come to that conclusion when new battery gets here. My question is that there must be a way to actually fix/revive the logic board. Perhaps some soldering involved. Is this possible? If so how can I find these tiny parts?
Is dit een goede vraag?
11 opmerkingen
Also I've seen a flashing green and orange light before. Why does my charger stay orange for a while and go green for a quick moment. Consistently and repetitively. I didn't know if the patterns in how the colors changed was an indication of what was wrong...
door
Try the new battery and get back to us with results. Then I can give you more accurate steps and information
door
I plugged in the new battery and the only thing that has changed is that the ac charger is no longer flashing but is now staying orange. Battery charge indicator button informs me that it is fully charged minus 1 blinking green dot. Side note: I poked my head around the internals and found some serious fray and exposure to 4 wires that go through the black bar connected to the screen left of the subwoofer.
door
@somexdude - How about downloading CoconutBattery and then paste a snapshot of the main window so we can see whats happening.
door
Well the macbook wont turn on so i'm not sure I can get a more accurate description towards the health of the battery. As for the fraying I don't have another computer to upload pictures with and it seems this website isn't friendly to uploading a picture through iphones. I applied a very small amount of pressure to these frayed wires and it was like they weren't even attached. It's the wires that go into the display of the screen.
door
6 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@somexdude like @e_ah said change the battery first then re-evaluate. This could be a bad MagSafe as well as dirty pins on it or a bad Magsafe DC-in board. Use these guides MacBook Pro 13" Unibody Mid 2012 to work on it.
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
Any other response for my new comment?
door
@somexdude please post a photo of your frayed wiring.
door
The problem is not the charger. I thought that the charger was blinking in a pattern that might explain why the computer was not turning on but I guess it was just random blinking. The charger is no longer blinking though just orange when battery is attached and green when it is not
door
Well, you've covered all the bases.
For additional info, check out this thread...
Not charging, blinking green/orange light
Best wishes...
Voeg je antwoord toe
Christopher Eaton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 652
