Ga door naar hoofdinhoud
The SKIL 4235 Jigsaw is a handheld power tool capable of cutting thin material such as plywood or plastic in a simple or complex planar design. The tool uses 120V AC input such as a household wall socket, to power a small blade, which can be dangerous if used incorrectly. Please consult the owners' manual for safety reminders.
3 Vragen Bekijk alle
Replacement part for holding blade onto saw
Blade attachment collar
My saw no longer holds blades tightly. The "key" just keeps turning in the "collar". The threads on either the key or inside the collar must be worn or damaged. Can I remove and replace the "collar" device? Removal instructions would be helpful.
Dennis
Is dit een goede vraag?
Score 1
2 opmerkingen:
@fern_dock69 your saw is a SKIL 4235 Jigsaw?
door
I also have this problem. Any suggestions for a quick fix?
door
Voeg een opmerking toe
1 Antwoord
Hi @Glenna L Baisden
Here’s a link to the parts for a Skil 4235.
The part number for the blade retainer (part #54 on diagram) is 2610346348.
Search online using the part number only to find suppliers that suit you best.
Was dit antwoord nuttig?
Voeg je antwoord toe
Dennis Kerrigan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 19
Altijd: 784
