Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Als opvolger van de PowerShot G7 X werd de Mark II in 2016 uitgebracht als het vlaggenschipmodel van Canon.
Screen is completely detached
My camera fell and there are no screws keeping the screen intact with the camera, so it's being held with the thin cable, which looks like a film. The film ripped, so now the screen is completely detached from the camera. What do I do??? How much would it cost to get the screen attached back to the camera? Also how much to replace the screws?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Aminat, I searched eBay for replacement LCDs for your camera. It looks like you can snag one from $25-30 USD that has fully intact ribbon cables. If you are confident in your technical ability, it may not be a bad idea to try yourself. If not, buy the part and a local tech who can swap mobile device and/or laptop screens should have no trouble doing this for you. If you are still under warranty, I'd recommend contacting the manufacturer first as the repair will void any remaining warranty you have.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
and here are the guides to work on your camera Canon PowerShot G7 X Mark II
door Deel
Would you happen to know what you searched when you found the screens on eBay I’m having a hard time finding them. Also having the same issue screen broke off from the camera
door Deel
Voeg je antwoord toe
Aminat Seriki zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 3,029
