Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Nokia 5130 XpressMusic is een van Nokia's mobiele telefoons in de XpressMusic-serie. De telefoon werd uitgebracht in januari 2009 en de productie werd gestaakt in 2011.
Contact Service Problem of nokia 5130
When i try to open my nokia 5130 mobile it shows a message --- 'contact service' on the screen. Then it becomes switch off.
How to fix this problem of my phone.
Is dit een goede vraag?
Score 20
5 opmerkingen
contact service problem on my mobile please give the solution..
Many thanks
door Deel
packet data connection
door Deel
my phone nokia 3100 is in contact service on the screen what shall i do??thanks
door Deel
Sir my Nokia 3220 mobile when I switch ON the mobile a contact service is written on display .what I can do?
door Deel
I have Nokia 130 contact service, would you tell about this post he is saying right. thank
post here. http://htfmobile.blogspot.com/2018/03/no...
door Deel
Voeg een opmerking toe
18 Antwoorden
Filteren op:
Gekozen oplossing
santanu, you could try to reset your phone
http://en.kioskea.net/faq/470-how-to-res...
1. *#7780# - Restore factory settings - resets all the settings to the default ( you will not lose any data)
Make sure you back up your data as you will lose all of it when you perform option 2 or 3 on this list. The default code for ALL operations listed here is 12345
2. *#7370# - Reformat your phone (out of the box, tho keep in mind that most newer nokia phones at least n series, e series and s60 based phones have udp - user data preservation so not ALL data may be lost. still it is a good idea to always do a back up of your stuff.)
3. This you perform as a last resort. Nothing else is working.If the phone is not showing any activity, proceed with hard formatting , turn off your phone, hold the following buttons while pressing the power button. (the default code is 12345)
hard reset - hold the following buttons *, 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons
http://discussions.europe.nokia.com/t5/O...
If none of this works you can also try to update your firmware. Download and install the latest Nokia Software Update and Nokia PC Suite, connect your phone, and run NSU. You will be prompted to update the firmware if a new version is available. Just make sure that you backup your phone since it will delete everything in th memory of your phone.
And if none of that works, you should definitely contact your cell service provider. Did you pay your bill :-)? Good Luck to you and let us know how it is going.
Was dit antwoord nuttig?
Score 7
3 opmerkingen:
The go to, menu and music options doesnt work. Help
door Deel
i can forget my password i try *=3=green button= power buton but mobile doesnt reset
door Deel
answer me
i am wating for ur rply
door Deel
when i try to open my nokia 5130 mobile it shows amessage-contact service on the screen. it becomes switch off.How to fix problem 0f my phone.
Score 4
Score 2
1 Opmerking:
Roy, have you tried any of the above answers?
door Deel
contact service problem restart
Score 2
when itry to open my nokia 5130 mobile it shows a message-contact service on the screen. it becomes switch off. How to fix problem of my phone.
Update
how to fix my problem.
Score 2
1 Opmerking:
service provider is needed
door Deel
Maybe you should contact service?
Score 1
Can be defective UEM IC..
Score 1
nokia 5130 contant servic ke bad band
Score 1
Score 1
i think there is hardeware problem, motherboard problem, and it will be fixed after changing of motherboard..
contak servesفحص المشكلة
pls help my nokia 5130 error contct service problem then on mobile after contact service off
jab mai koi work nahi karta hu mobile par toh wo automatic switched off ho jata hai.....please reply
*#7782#
عندما افتح الهاتفنوكيا xpressmusic5130 تضهر رسالة تقول كونطاكت سيرفس
my hp, just live with the error tuliisan "nokia" just ...? whether the damaged ... and serial number while still living a beautiful number ...? ask for the explanation ... thanks
contant sarvic ke bad off
== Heading text
Voeg je antwoord toe
santanu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 53
Altijd: 100,502
