How to replace front glass?
I would really appreciate a guide on how to replace the front glass for my daughter's 2014 kindle. thank you in advance foe any help.
Is dit een goede vraag?
you are not telling us the exact Kindle that you need help with . The device you picked is the FireHD 7 and you can use this guide Amazon Fire HD 7 (4th Generation) Display Replacement for that
matthew santiago you will have to follow the above guide in its entirety. You then need a heat-source like a good hairdryer or a hot air gun at it's lowest settings to soften the adhesive that holds the touch screen to the frame. Soften it with the heat-source and remove the touch screen with same plastic tools like guitar picks etc. Check this video from 7:54 and proceed identically to it.
Was dit antwoord nuttig?
I am requesting info on repairing the glass, not the LCD.
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 562
1 Opmerking
This question is in the Amazon fire hd 7 section.
door matthew santiago
