Ga door naar hoofdinhoud
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1191 Vragen Bekijk alle
Need to change the processor
My Acer Aspire 3002NLC laptop's current processors tends to heat up a lot and stops working midways also. Its @@@& slow too.
I have tried cleaning the CPU fan. I replaced the thermal heatsink too...twice. Still it runs pretty hot. ~90-95'C.
Was thinking of changing the same to something new. Can somebody pls let me know what would be a good replacement to the same.
BTW my current processor specs are as follows -
Processor Type: AMD Mobile Microprocessor
Model Number: 2800+
Part Number: SMS2800BQX3LF
Package: 754-Pin Lidless Micro-PGA
Form Factor: Socket 754
Manufacturing Process: 0.09 micron
Stepping Codes: ABBWE, CBBWE, CCBWE
Frequency: Rated 2800+ - *Real 1600
Level 1 Cache: 64KB Instruction Cache and 64KB Data Cache
Level 2 Cache: 256KB
Special Features: Enhanced Virus Protection and PowerNow! Technology
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If your laptop is running more slowly than usual or has become increasingly slow over the past several weeks or months, see the Acer Aspire 5253 Is Running Slowly problem page for possible problems and solutions.
The manual for your laptop says:
Mobile AMD Turion 64 processor ML-28/ML-30 or higher
Mobile AMD Sempron processor 2600+ to 3000+ or higher
are supported, that is where I would start out with if anything. I believe it's a PITA to change the CPU in one of those. The manual is available at acer.com a list for CPU's is at AMD and here is a least of the Turion 64 for the mobile computing market
Remember that speed and heat go together and that in order to make your computer more effective I would also look into increasing/changing memory and possibly optimizing your OS. Good Luck.
Was dit antwoord nuttig?
Score 1
Check this website for all compatible socket 754 processors:
http://products.amd.com/en-ca/desktopcpu...
You'll want to be sure your motherboard/laptop BIOS will support the CPU you select. You should be able to check the manufacturers website for this information.
It looks like the highest performing CPU is the AMD Socket 754 3700+. The processors are running around $70 on eBay.
1 Opmerking:
your link is for the desktop processors.
door
Voeg je antwoord toe
swapnil zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,081
