Ga door naar hoofdinhoud
The Xperia Z1 Compact is Sony's premium camera phone. It is similar to the Xperia Z1 model except smaller and less expensive. Its key feature is a 20.7 megapixel sensor. Upon release the available colors were white, black, pink, and lime. This device can be identified using the model number (D5503)
20 Vragen Bekijk alle
Sound Muffled without Headset
People describe me as muffled, talking in a cave, or breaking up when I'm not on the headset. Sounds like there's a problem with my mic. What can I do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @nygal ,
Use a strong light and a magnifying glass to visually inspect the voice inlet hole, found on the bottom edge of the phone, to see if it is blocked with dust or lint.
If it appears to be blocked use a vacuum cleaner, using short sharp bursts, to try and clear the obstruction.
If you don't have a magnifying glass try the vacuum cleaner anyway and then make or receive a call to test if it has been fixed.
Do not use a probe to try and clear it as the phone's microphone is directly behind the hole and could be damaged if you do.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Helpful but it didn't fix the problem, unfortunately.
door
Voeg je antwoord toe
Laurie Barrueta zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 273
