Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht in 2014, te herkennen aan het 11,6-inch scherm, een 2-in-1 convertible touchscreen-laptop. Modelnummer 11t-n000.
How to replace a cracked screen?
Hey! I dropped my HP Pavilion 11-n011na x360 and unfortuantely there are two cracks on the screen, I was wondering how I would find the exact replacement screen as I've seen a few different ones and I'm completely clueless when it comes to this type of thing and how I would go about actually replacing the screen, I haven't seen any guides on the HP site or here.
Thanks!
Is dit een goede vraag?
Score 2
1 Opmerking
Hi try to check this service manual
http://h10032.www1.hp.com/ctg/Manual/c04...
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Hi @lecollecteur,
The service manual gives instructions regarding the necessary pre-requisite steps and then the procedure on how to remove the LCD screen. (see p.58 in the manual)
On p.15 of the service manual, you'll find the 4 types of LCD screens used for the different variants of this model. To be absolutely sure that you have the correct one for your laptop, the part number will be stamped on the back of your LCD screen. You'll have to dis-assemble the laptop to remove the screen to find out of course.
Once you are satisfied that you have the correct part number, search online using just the part number only, to find suppliers of the part that suit you best.
Was dit antwoord nuttig?
Score 3
Hi try to check this service manual..
Score 2
Voeg je antwoord toe
lecollecteur zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 2,721
