Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Polaroid OneStep 600 camera maakt en ontwikkelt zijn eigen foto's. Hij is voorzien van een automatische flitser en een speciale lens voor close-upfoto's.
How do I/Can I replace the flash?
The flash in my camera will fire up when I open the camera but nothing happens when I take the picture. Meaning that the light comes on and I can hear the sound of the flash warming up but it doesn't fire when I take the picture. Is there any way to replace the flash in this particular camera?
Update (12/25/2017)
It sounds like I might need to just buy a new camera, the thing is pretty old so I can understand if that's the case. They are pretty cheap on eBay..
Is dit een goede vraag?
1 Opmerking
@kaitlinm it's not about being to old or inexpensive. Why not try to fix it? Bear with us and I am certain you'll get some responses. Never give up on fixing the world, one device at a time.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
@kaitlinm start by checking this teardown Demontage van de Polaroid One-Step 600 about how to remove the flash
Was dit antwoord nuttig?
Score 1
1 Opmerking:
It looks like you essentially have to remove half the camera before you come to the flash and even if I did that, I would need to know what part I was replacing and where to get it. To me, I don't know it's worth all the extra time and effort. I would be more willing to pay someone to fix it for me at this point. I try to get as much use out of something as I can and fix things on my own when they're broken but this might be too complicated a job for me.
door
Hi Kaitlin, did you have any luck finding anywhere to repair your polaroid flash? I am determined to get mine fixed, seems to be a similar issue to yours. Camera fires up, but no flash, and fantastic shots are ruined by coming out blurry as a result!
Voeg je antwoord toe
Kaitlin Muro zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 75
Altijd: 5,242
