Ga door naar hoofdinhoud
The Officejet is HP's line of office inkjet printers.
356 Vragen Bekijk alle
Curious about what a part does
I was just tearing down this old HP printer because i got a new better one, and I came across something strange. It looks like a piece of metal with a slit cut into it for the wire. This wire wen't to the display panel/buttons. And on a note, this object was slightly ferrous. It was weak though.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @parzival ,
Just guessing, but since the cable seems to be passing through it it may be a type of ferrite choke designed to filter the EMI effects on the wires going to the display panel. (like what is found on better video cables connecting a monitor to a PC etc)
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I could see that. After going deeper, it was on EVERY ribbon cable in the printer. And i could especially see that because there are at lest 3-4 motors in this printer.
door
Voeg je antwoord toe
Kevin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 43
