Ga door naar hoofdinhoud
A tablet released in September of 2015 by Amazon featuring a 7 inch multi-touch screen display. Model Number: SV98LN
Black Tape Torn on Digitizer - Amazon Fire 7" 2015 Edition
Attempting to replace the motherboard on an Amazon Fire 7" 2015 model. I did not remove the digitizer before removing the motherboard (as instructions say I should do). I tore the black tape in order to release the motherboard. Am I now going to have to replace the digitizer? Or is everything ok,
You can see the digitizer is still attached to the motherboard. You can also see the black tape that was torn holding it.
Thank you!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@terdallaujar not sure which black tape you tore. Post some images of your damage with your question so we can see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that. For as long as you did not tear the ribbon cable you should be ok, but we need to see the damage to make that determination.
Was dit antwoord nuttig?
1 Opmerking:
Thank you...I should have done this to start with!
door
Voeg je antwoord toe
Kensey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 123
