Ga door naar hoofdinhoud
Speelgoedquadcopter met camera, bediend via wifi met een smartphone.
Is it possible to change the camera?
I wonder if it's possilbe to change any or both the cameras with a better quality camera ???
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
I do think that this is a depends answer. Depends if you have the Drone, and can actually get the physical dimensions to replace it with cameras that are of comparable dimensions in order to not alter the flight characteristics of the Drone. Then it depends on the firmware/software that the drone uses, it may be specific for the cameras, and may not accept anything else. The only way to make sure that you can, is by doing it....let us know if you are going to so we can all learn something. Good Luck :-)
Was dit antwoord nuttig?
Score 1
You have to buy the AR Drone Bottom Structure from parrot.com or Brookstone.com and goes for $59.99. I have yet to find a camera sold by it self.
Yes
Voeg je antwoord toe
Ali Ghasser zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 7,413
