Screen keeps turning off, when turning on!
When turning on the phone will not boot and the display keeps turning on and back off.
Here is a video of the problem: https://youtu.be/OW-MsQnLGEM
Is dit een goede vraag?
It seems to be bootlooping. Has the screen or any other part been replaced?
Was dit antwoord nuttig?
The battery has been changed it is a lot better than the old one.
Did you change the battery then that started to happen or did it start happening randomly and the battery was replaced awhile back?
It was happening randomly and yeah the battery was done about 6 months ago now.
Did you do the repair yourself?
Yes, I repaired myself, tried the battery in my friends 6 and it doesn’t boot loop so the battery is fine.
Check your battery is charged up and good. There are a few things that cause Boot Looping, but one of the first things to check is a strong battery or use a DCPS to power it up .
Then follow up with what lead up to this. When was the last time it booted normally, did a drop, water damage, etc... happen before it stopped. and as Carlos asked, have you replaced anything recently? opened the phone??
After a while it eventually boots normally but then it will start boot looping during the day of usage.
I am also having this problem after I replaced my screen.
You just need to ket it charge to a level that the phone can operate correctly.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 100
