Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
iPhone 4S Battery Connector detaches and takes out one pad
My surface-mount soldering skills are on the basic level.
I got set back even further when I saw one of the pads had also detached with the battery connector.
I actually heard the iPhone 4S can function without a battery.
How should I restore functionality on that detached pad? I will go hunt for a schematic.
What's the likelihood of restoring the phone to usable condition? We want to perform data recovery, at the very least.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
that pad can be jumped to the test point just to the left of it in the photo
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
The test point is the golden dot? What kind of wire should I use to connect?
door
yes the test point is the golden dot, magnet wire around 0.1mm or a bit thicker if needed
door
Voeg je antwoord toe
lkvee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 57
