Ga door naar hoofdinhoud
The 2003-2005 Pontiac Sunfire is a more streamlined updated version of the popular car.
7 Vragen Bekijk alle
Why is there gas spraying into the tube that leads to my air filter?
There is a small black hose that leads to the tube my air filter is in & the other end is on a cyndrilical metal like item...something to do with fuel I'm guessing. Gasoline comes out the end that goes into the tube that leads to my air filter, my car popped & started smoking the other day after I tried to start it, I took the air filter out, the small black hose off & plugged it up...help! What is the metal cylinder shaped item that the other end of the hose i's hooked up to called?
Thank you.
Is dit een goede vraag?
1 Opmerking
@bsrigamarowe post some good pictures of what you are looking at with your question. That will allow us to see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that.
What exact year is it and hat engine size does it have?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The only line that should be attached to the air intake is the pcv exhaust . Are you sure this has gas coming out or is it oil . you may need to replace the pcv valve if your getting excessive blow by. The cylindrical item is the PCV valve . Hope this helps
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
It is definitely gas, my air filter was covered in it which is probablying why it popped & was smoldering when I tried to start my car. When I had the hose attached it was my car had a difficult time starting, I had to pump on the gas pedal & when I'd let up it'd start. Now that it's disconnected it starts just fine.
door
@bsrigamarowe could you post some photos of the part your talking about
door
Voeg je antwoord toe
Bernard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 2,353
