Ga door naar hoofdinhoud
De SONOS PLAY 5 is de originele, alles-in-één Sonos-muziekspeler voor grotere kamers met een krachtiger geluid.
High voltage fuse blowing immediately
Hi,
My Sonos Play 5 (Gen 1) is blowing the internal high voltage fuse immediately when i'm turning the power on. Anybody who can assist with a schematic of the PCB or any who have seen this kind of problem before?
Afbeelding
For info, I'm currently sitting on the northsea on a olieplatform and there is a bit lack of spare parts. But i have the most standards parts.
Is dit een goede vraag?
Score 2
13 opmerkingen
@laversen disassemble it and post some images of the boards with your question. That would allow us to see what you see and maybe even see something abnormal. Use this guide or that Voeg afbeeldingen toe aan een bestaande vraag
door
@oldturkey03, The post have been updated.
door
Is the repair has been successful? What was damaged ?
I have the some problem
Fuse blown
I look on the diode bridge , but shorts is on the pcb d27718 pin 1 to 3. No shorts on the diode.
Thanks for any help.
door
Same problem! But were can I find the fuse?
door
Hi @ ceeskoedijk,
Do you mean where is the fuse located on the board?
If you look at the image posted above the glass fuse is on the board just above the power input socket.
If you mean what value is the fuse and where do you get it?
Remove the fuse and check what is stamped on the metal ends. There will be a Voltage (V) and Current (A) rating and if it has a T (indicates slow blow)
Also measure the length and diameter of the fuse cartridge
Once you have all the information search online for a (insert values ) fuse to get results and then check for one that has those values with the correct physical size.
door
8 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
It sounds like a problem in the power supply section. An electrolytic capacitor with a domed top or showing signs of leakage will hopefully give you a quick win, but otherwise my guess would be the rectifier or switching transistor on the high voltage side.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Also what i was looking into at first.
At first I changed the big capacitors, no help. After i wrote the post yesterday I have changed the diode bridge, it's was shorted, now the fuse don't blow. But it still dosen't shows any signs of life.
door
Next would be the switching transistor on a heatsink just south of the transformer in your photo. There's also an 8-pin IC down that way, and if you can identify and replace that it'd be worth doing. And I can see 6 surface mount transistors. These will have abbreviated type codes. If you can identify them as junction transistors you can test them (more or less) in situ with the diode range of a multimeter, and whatever they are, a short between any 2 terminals would point to trouble.
I had a glance at Google for schematics but found nothing. Sometimes you can have more success with yandex.ru or baidu.com though a quick look didn't come up with anything.
Hey, if you're on an oil platform I'd guess that a power surge created by some heavy electrical machinery might be what has done the damage.
door
Voeg je antwoord toe
Peter Lauridsen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 6,880
