Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
No automatic Brightness adjustment after screen replacement
I changed my screen two days ago because of a cracked screen. I already bought not the cheapest replacement kit I could find.
Installing the new screen went great. But I noticed that the screen brightness wouldn't adjust automatically after that. I tried everything I could find online, from re-calibrating the brightness sensor, to turn the feature off, and soft reset the phone. I did not try to reset all my settings because that's what I'd like to keep.
Does anyone has a new idea?
I don't mind opening the phone up again to solve it.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Your ambient light sensor is either bad or wasn't reinstalled correctly. Step 25 in this guide: iPhone 6 Vervanging van het LCD-scherm en de digitizer
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
I bought an completely new display unit. Does it mean the display does not have a brightness sensor built in? And I have to replace it with the old one that worked in my broken display?
door
I have no way of knowing if your display has a brightness sensor built in. Where did you buy the display from? Is everything else (earpiece speaker, camera, etc) there? The brightness sensor is part of the camera flex cable.
door
In fact, it was the brightness sensor built into the new display. I changed the camera flex cable with the original one and it works perfectly fine now.
Thanks a lot.
door
i need brightness in screen
door
It happens when your phone has Amoled or Oled display but the replacement screen you brought is probably a Chinese LCD . Amoled phones has different way to control brightness by varying brighness of each pixel and it cant support backlit control for LCD screens.
Hi! I bought a new screen for my iPhone 6S plus from ifixit and followed your suggestions by repleaceing the new brightness sensor with the old one , but it doesn’t work anyway…
Voeg je antwoord toe
Kevin K zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 8,644
