Ga door naar hoofdinhoud
The Ematic FunTab 2 is a 7" Quad-Core 8GB kid-friendly tablet. It comes pre-installed with a variety of educational games, a parental control dashboard, a front facing camera, a 2 megapixel back facing camera, and other productivity apps.
16 Vragen Bekijk alle
Charging port burned out
I bought my daugter an ematics funtab not even4 months ago and im thinking the charging port broke on it already, it wont charge anymore so we cant use it.. im trying to see where and how much it would be to send it in to get it fixed... if someone could help me thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Anne Strawn since this is a relative new device I would suggest that you contact the place where you purchased it from and see if it is covered under warranty. If not, it might be a bit tricky since this is not a very common tablet. You can try and check the port by using this guide Ematic FunTab 2 Motherboard Replacement to get to it. Check the solder joints to make sure they are still properly attached. Take plenty of pictures and post those with your question so we can see what you see and help you a bit more if needed. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that.
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Ematic FunTab2 Motherboard Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
1 hour
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Anne Strawn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 103
