Ga door naar hoofdinhoud
A 35mm FD-mount single-lens reflex camera introduced in April 1984 as the second in Canon's T series.
Where to find replacement parts
How do I replace old parts on this older model camera?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hannah Bynum you did not tell us which part. This manual 1.EPS should have all that you need to repair your camera.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
It needs a new battery cover, off/on switch, and socket cover
door
Check for the numbers in the parts list in the SM. For example, the battery cover is part number CY1-1164-000 and available at places like this Not sure which socket cover you need but it might be part number CA4-1847-000 available at the same place.
door
tenho uma toda funcional , prisma com muito fungo e lente um pouco o restante toda ok . se interessar….
Voeg je antwoord toe
Hannah Bynum zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 1,639
