Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 screen popping out
The screen is popping out at where the volume and mute buttons are after a screen replacement.
Is dit een goede vraag?
Score 3
2 opmerkingen
My iPhone 6 screen has popped out to the left of my home button I hemnes help
door
Faye Mine is like that only on the right. Something under my home button slid backwards and now the button wont work.
door
Voeg een opmerking toe
8 Antwoorden
Gekozen oplossing
Common issue with iPhone 6 aftermarket replacement screens.
Few things to check:
Make sure the frame is clean and not bent in any way, the corners or the iPhone housing as a whole.
If it's bent you should straighten it flat so that the screen can sit flush
Dents going inwards in the frame on the edges need to be bent back into place as well, especially at the corners of the frame where the screen sits on.
Other than that getting better quality screens (one with better screen frames that sit in properly and don't have the infamous gap near the vibrate switch / volume area).
Was dit antwoord nuttig?
Score 5
2 opmerkingen:
How would I go about trying to straighten the frame if it is bent
door
Hi
One of the cause could be due to the phone battery as the battery heat up the paper wrapping around it expands to push out the screen
door
hii,
So, my iPhone 6's front top left corner of the screen appears to have "popped out" (Best way to phrase it)... I don't know whether I should go to the geniuses or try to pop it back myself... It appears to have popped out of the hook inside the phone, and if i jam it a little i can put it back in, but I'm afraid that it'll crack the screen. What should I do?
Thanks!
I didn't find the right solution from the Internet.
References: https://discussions.apple.com/thread/685...
web video marketing
2 opmerkingen:
get a pentalobe screw driver and remove the bottom screws. pry the screen up from the bottom and around the sides and then reinsert the screen and replace the screws.
door
This comment by Henry Mang is the answer! you need to take the screws out next to the charging port with a P2 bit and then use a guitar pick to pry the rest of the screen off. Once off, insert the screen clips first and then press the rest of the screen back down along the edges to re attach to the adhesive. screw the 2 screws back in.
door
did not help at all because the screen is popped out
i dropped my phone now it cracked and the screen popped out and it wont turn on HELP !!!!!
1 Opmerking:
replace the screen
door
So my home button to my iphone 6 had an issue where the left side of it was stuck up and the right side of it was stuck down I fixed it but now my whole frame around the edges is popping out what should i do and we went to the store and they said it was the home button and it should pop back but it is the screen PLEASE HELP ME!!!!!!!!!!!!!!!
I had same problem I went on eBay and bought the iPhone screen tape £1.95 worked a great
1 Opmerking:
My IPhone 6split open on the left side took it in to repair shop he checked they battery was good so he fixed it and charged me $15 it’s great now!
Why does it happen?
door
My dumb sister sat on my phone screen and it the top was already popping off then boom fat sister made it worse i’m so mad she will pay oh yes she will
The left side of my phone is popping off I need to fix it but idk what to do help me!!!
Voeg je antwoord toe
Haris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 75,747
