Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor de eerste generatie Nissan Murano, van modeljaar 2003 tot 2007.
Grounding Points on 2005
I have a 2005 Nissan Murano and I am having a few issues with sensors and my engine running really rich. I was advised by a mechanic friend that the issue could be caused by a bad ground. I am trying to find all the grounding points on my SL Murano. I have only been able to find 2. 1 below the battery and 1 off the timing chain housing.
Any suggestions? or could i just run new grounds from the battery?
Thanks,
Jarrett
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sande Jarrett it would probably be easier to run a new ground than trying to find a bad one. Make sure you remove all paint and primer before applying a new ground and use some self tapping screws to attach it.
Now if you really, really want to know where all the ground points are, here is the manual for that :-) Nissan-Murano-Ground-Distribution.pdf
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks!!! this is really helpful.
door
Voeg je antwoord toe
Sande Jarrett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 5,863
