Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
Have I ruined my iPhone? Problems after WiFi Antenna Fix
Long story short: WiFi was greyed out and read on here that I needed to replace the antenna (iPhone 6s Wi-Fi Diversity Antenna Replacement). Anyway I did it and all seemed to have gone well however:
Phone wouldnt power on so plugged in and switched on fine. No discovered not only does the wifi still not work, the power button volume and the mute button have all stopped working.
Any help would be much appreciated as I feel I've just wasted $300 and going to have trade it in for $20 :(
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Not a big deal. You damaged that cable for those things. I mean, you have to remove basically everything to get it out, and the batteries are nice n tricky to get out, if you don't do them all the time. Also double check your connections to make sure you did a good job of getting those back in. I'll post some guides and parts. If you don't feel comfortable. Them bring it to your good local repair shop. Check their reviews. As for your wifi, well let's double check your work, make sure you put that antennae on there the way it's supposed to go
iPhone 6s Audio Control Cable and Brackets
iPhone 6s Upper Component Cable Replacement
iPhone 6s Audio Control Cable and Brackets Afbeelding
Product
$19.99
iPhone 6s Wi-Fi Diversity Antenna Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
1 - 2 hours
iPhone 6s Upper Component Cable Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 3 hours
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Just took out the logic board and put it all back in again and the original problems have been fixed and its how it was before; the wifi remains greyed out. Just wondering if you know what I could do to fix this? WiFi sign greyed out and bluetooth continuously spinning.
door
You can't fix grey wifi by replacing the antenna, it's like your car won't start and you replace the tires.
This is board problem, find board repair guys to fix it for you.
Score 1
Voeg je antwoord toe
Matt Howard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 506
