Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Braun Exact Power EP100, uitgebracht in 1999, is een elektrische baard- en snor-trimmer. Het apparaat heeft een interne oplaadbare batterij.
Disassempling of the Braun EP100...?
How do I disassemple it? It is impossible without destroying the halfshelves that covers it........?
Is dit een goede vraag?
Score 1
2 opmerkingen
Did you check for a replacement cost from Braun, I just replaced my unit that was over 300 bucks for about 50. Series 7
door Deel
Finally I managed to open and repair it.
it felt from my hand, and refused to work anymore.
So decided to open and check the issue. I had to force a bit , nothing to complicated, but the clips were very tied, thats why anyone is scared to insist... Finally it was the negative pin of the battery that was cutted from the board, so just resolder it to the board, and it was good to go :)
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
@nlzhlm the EP100 actually is a Braun 5601. Yes it can be disassembled without breaking it. Here is the SM Braun EP100 service manual that shows you how to work on it.
Was dit antwoord nuttig?
Score 4
I got the same problem, I need to open it, but arrived to the point where the cover is strongly held. I dont want to force to dont destroy it. did you finally manage to open yours??
Thx
Edit:
Voeg je antwoord toe
Niels Holm zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 30
Altijd: 2,357
