Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De iRobot Roomba 770 is een draadloze, autonome stofzuiger die je vloer zonder toezicht schoonmaakt.
Blue light flashing on robot
There is a blue light flashing on the machine and it is making a thumping sound
Is dit een goede vraag?
Score 1
2 opmerkingen
My blue flashing light looks like a magnifying glass, what is that for.
door Deel
I have a flashing blue light but the indicator looks like a small circle with a few emitting beams, also the side brush is not moving at all.
door Deel
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
@baldly Roomba 700 and 800: When in Dirt Detect mode, the blue Dirt Detect indicator will flash. You did not tell us which light. The dirt detect is the magnifying light. Make sure that you check the brushes and clean them well. If there is debris stuck on those they may trigger the dirt-detector sensor and you get your blue light flashing.
Was dit antwoord nuttig?
Score 6
2 opmerkingen:
I keep my roomba pretty clean. I cleaned thoroughly and it worked for a few minutes. Then it went back to blue light and thumping noise. Any more suggestions?
door Deel
I have exactly the same problem
door Deel
I had a blue star flashing and a thumping sound. I have the 770 model, so I went to the Roomba site and found this video: https://homesupport.irobot.com/app/answe...
It was simply a matter of cleaning the front wheel (I did not know it came out to clean it) and cleaning the brush and roller (I actually replaced them since I had spare parts on hand).
Score 3
2 opmerkingen:
Blue star flashing after replacing filter roller and cleaner? what does that mean it's not the magnifier it's just a blue star I've never seen it before?
door Deel
bingo! I've had this one for EVER and it has never done the bumpity thump blue star flashing before. I always pull the front wheel out and clean but have never pulled the plastic insert it slides into out. I had a big wad of fuzz under it. cleaned it out and VOILÀ, back in biz.
THANK YOU
door Deel
Blue star like light is indicating problem with brush movement.
I found dirt under the silicon cover that prevent the brushes from turning.
Voeg je antwoord toe
Jack Luhring zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 54
Altijd: 46,470
