Battery Plate Causing Completely Black Phone
Today I was using my phone when all of the sudden my screen went black. I tried resetting it in DFU mode, error 4005. I read that the front camera could cause that issue, so I opened up my phone, naturally unplugged the battery and then the front camera. I replace the battery connector but not the plate over it. I was able to get my phone to restart back into working condition. I thought it was strange, but then replaced every connector and plate, to find my phone went black again. After more trial and error I found that it was my battery plate, that when I screwed it all the way down it would cause my phone to freeze and go black. Are there any solutions for this? Should I just not put the plate on? Or should I try something else? Any help is appreciated.
Is dit een goede vraag?
1 Opmerking
Update: Apparently my phone becomes unresponsive when there is too much pressure being put on the battery connector, which happens when you put on the plate. If I press down on the connector without the plate, I get the same result. Does this mean I should just get a new battery?
door Bayn
