Ga door naar hoofdinhoud
Samsung-smartphone uitgebracht in januari 2016. Model SM-J320
How do I fix a black screen?
I had recently gotten a samsung galaxy j3. I accidentally dropped it into a pool, and dried it, I waited a few days and after a while, it turned on. the screen is illuminated, but stays black. Ive tried everything, even a reset but the screen stays black, The phone vibrates and the flash stays on when charging, but nothing happens screen wise, Do I need to get it replaced?
Is dit een goede vraag?
Score 1
1 Opmerking
I recently got a samsung galaxy j3, incidentally dropped into water, i dried it up to a week to ensure its totally dried. I put the battery and power it ON, it turns ON. Every thing functions perfect, but there is no light on the screen (dark), Its charging well. Please what do I do? can someone help..
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
There is a tricky part here. You dropped it in water, therefore it needs to get cleaned out immediate to prevent corrosion. This can be done with 90% isopropyl alcohol
There is still a chance the phone may work after cleaning, so don't give up!
If you cleaned the phone and issue still appears to be the same, then you will most likely need to replace the screen. Not sure if you have the exact model you posted but here is a breakdown for the a J3
If you're not comfortable in this realm, just take it to a shop and inform them it was dropped in a pool.
Hope this helps
Was dit antwoord nuttig?
Score 2
my phone is brokekin
Update (09/02/2018)
its my screen my phone is broke
Voeg je antwoord toe
Mikey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 3,546
