Ga door naar hoofdinhoud
The BlackBerry Classic (also known as the BlackBerry Q20) was released in 2014. Model numbers: SQC100-2, SQC100-3, SQC100-5.
20 Vragen Bekijk alle
The phone overheat pretty much
Hi Sir,
Well, I also bought blackberry classic q20 last month but I have started experience the same problems of the phone overheat pretty much and yet I don't even use the phone a lot and I just use only caling and check the Internet in 30minutes but the phone overheat seriously. I real need help over that problems. Thanks Chris
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@ochan885 you do want to start with a new battery. It is possible that the battery is at the end of its lifecycle and starting to fail. Replace it and let us know if that made a difference. the first few steps of this guide show you how to remove the battery.
Was dit antwoord nuttig?
Score 2
These snapdragon S4 chips like to get really hot under load. Heat is pretty normal. The phone has several thermal sensors and will power off if it gets too hot.
Score 1
Voeg je antwoord toe
ochan christopher zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 416
