My frame around the screen at the bottom corner cracked
Frame at the bottom corner of the screen around the joint when the screen opens and closes cracked
Is dit een goede vraag?
@cmeyer0922 not quite sure what you are looking at. It sounds like your bezel is cracked. To verify this, post some images of what you are looking at, with your question. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that.
If it is the bezel alone, use this video. Slightly different model same idea.
If it is that the hinges are actually braking the case/frame then you should get this covered under warranty. After all the GE72 should still be pretty new.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 1,265
