Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Dit is de apparaatpagina voor de Samsung Galaxy J7. Het besturingssysteem dat standaard op het apparaat wordt geleverd is Android OS v5.1.
Flickering when low light
How to solve plssss my j7 flickers when on low light how to fix help me pls should i replace the lcd or their is other things to replaced or it just needs something to be solved ?
Is dit een goede vraag?
Score 5
1 Opmerking
my samsung J7 camera light cannot go off. steady ON
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
@kobexkyrie seems to be a very common issues with this model. It is the backlight that is flickering at higher/lower power demands. Could be filter or power IC as well as the Amoled. Take a look at Flickering screen on low back light and see if some off that will work for you.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Sir what do you mean of off ?I just updated the model than it started flickering
door Deel
@kobexkyrie of off ? I was stating that this seems to be a common issue with this model phone. Check the answers on the link in my answer to you. Click on the light blue writing :-)
door Deel
Thanks for the help it helps me a lot to save
door Deel
Sir unluckily it didnt work even the screen filter doesnt work also what should i do
door Deel
I replaced with new battery and problem went away.
Voeg je antwoord toe
Fixie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 17,574
