Ga door naar hoofdinhoud
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Vragen Bekijk alle
It will turn on but only charge to 50%
My samsung galaxy S6 got rained on, and since then it will turn on and screen looks normal and functions normally, but it will only charge to 50%, but when I unplug it then it dies. Do I need to replace the charging daughter board? If I do, then will the home button finger ID still work?
Is dit een goede vraag?
2 opmerkingen
Both front and back are cracked, between replacing the battery and both front and back glass. Is it cheaper to replace phone?
door
Unless you know how to do a glass only repair, it is usually not worth fixing. If the LCD is black, I would just get a replacement then.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sounds like your battery is failing to due liquid. Any time you get liquid on a battery, you want to go with a new one. I would first try a new battery before replacing the daughterboard. If battery fails, then try the board. That should solve any issues you are having with this device.
Samsung Galaxy S6 Vervanging van de batterij
Samsung Galaxy S6 Daughterboard Replacement
Samsung Galaxy S6 Batterij Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
40 minutes - 1 hour
Samsung Galaxy S6 Daughterboard Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
45 minutes - 2 hours
Was dit antwoord nuttig?
Both front and back glass is cracked, and bad battery, with all of these repairs, would it be cheaper to replace the phone?
Voeg je antwoord toe
Amy ford zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 18
Altijd: 153
