Ga door naar hoofdinhoud
Uitgebracht in 2007, model F130W. Beschikbaar met 512MB of 1GB intern geheugen.
How do I fix a coroded battery pack?
How do I fix a coroded camera battery pack
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@shejskaw, Sheila, If it is the battery pack it self that is corroding, consider replacing it as it could be damaged/leaking, perhaps do a search using your model# for replacement. You can use the link below to open/access the battery compartment/contacts and give them a good cleaning. The eraser end of the ink pen is slightly abrasive and works well, scrub it across the battery contacts, a little work and patience and you should be able to remove the corrosion. blow or gently shake out any eraser shavings. Qtip/soft cloth dampened with 90%+ Isopropyl Alcohol will also work to clean terminals of corrosion. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Buitenkant van Flip Video demonteren
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Sheila Whale zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 351
