Ga door naar hoofdinhoud
7.7" Android tablet released in February 2012. Samsung P6800
Tablet does not charge
Tablet has not been used for over 3 weeks, and totally discharged. When USB charger plugged in, the battery charge simbol comes on, left to charge overnight. After 10 hours of charge time the battery charge symbol is still on even after the charger is unplugged, and the unit would not turn on, no matter how long you push the on button.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
George Schwanauer, The battery, cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections( clean with Qtip dampened with 90%+ Isopropyl Alcohol) and reconnect/install battery, still not charging battery probably faulty. Below is a link to show how to partially disassemble the phone to check some components and replace battery if need be. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Samsung Galaxy Tab 7.7 Battery Replacement
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
George Schwanauer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,050
