Ga door naar hoofdinhoud
Samsung Galaxy Tab 7.7 Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: stap 1, afbeelding 1 van 3 Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: stap 1, afbeelding 2 van 3 Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: stap 1, afbeelding 3 van 3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Battery Replacement, Disconnecting the battery: stap 2, afbeelding 1 van 1
    • Detach the five wire connection of the battery from the motherboard. You will need to gently insert a flat head screwdriver under the connector, and using left to right motion with your wrist, create a small space separating the connector from its connection. Gradually make the space wider until the connector pops out of its socket.
  3. Samsung Galaxy Tab 7.7 Battery Replacement, Unscrewing the battery: stap 3, afbeelding 1 van 1
    • Remove the 6 screws securing battery.
  4. Samsung Galaxy Tab 7.7 Battery Replacement, Replacing the battery: stap 4, afbeelding 1 van 1
    • Remove the original battery, replace it with a new one.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Stephanie Wong
973 Reputatie
5 handleidingen geschreven
USF Tampa, Team 13-2, Staggers Fall 2014 Lid van USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 7,815
