Ga door naar hoofdinhoud
Google Home voice-activated speaker, equipped with Google Assistant. Announced October 4, 2016 and released November 4, 2016.
10 Vragen Bekijk alle
My google home has stopped working completely
When I turn it on I get 2 vertical lights, then a cross of 4 lights, and this repeats....
It's not connecting to the internet, and not responding to any questions
This started about a week ago. For the previous 6 months it has been ok
I suspect its a software update problem. Can you help me?
Is dit een goede vraag?
Score 9
7 opmerkingen
Could you take some pictures of both lights?
Voeg afbeeldingen toe aan een bestaande vraag
door
I have the same problem but I have no lights whatsoever on mine
door
lights turn on but alexa doesn’t speak
door
My Google Home is not working
door
Google home says it's not connected to the internet
door
2 commentaren meer tonen
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
Each of these won’t take more than a few minutes at most, so when Google Home doesn’t respond:
Press the microphone mute button to see if Google Home was muted accidentally.
Unplug Google Home before waiting at least a minute to plug it back in.
Gently blow on both black dots on the top of Google Home, and then wipe the top with a soft and dry
Perform a factory reset by pressing and holding the microphone mute button for 15 seconds until you hear the confirmation from Google Assistant. A factory reset will clear all personal data from Google Home.
Was dit antwoord nuttig?
Score 7
I had the same issue with my Google home.
But after updating my home address, its work like a charm. Update your as well:
Open the Google Home app on your Smartphone → Tap on the hamburgerMore settingsGoogle Account settings → Update Personal info.
If this solution does not work for you, then try some other fixes to solve Google Home not responding problem.
Score 4
1 Opmerking:
The new google home update crashes upon setup. I have Android 4.4.2 so it "should" work. Jimmycurk@gmail.com
door
It was a software update issue. Had to reboot the whole thing and reset it…..
Score 2
Chinese troep. Ik heb het probleem niet meer. Ik heb het in de vuilnis gegooid
My Google home not working
1 Opmerking:
Past 30days:179 not working
door
Voeg je antwoord toe
Andrew Whigham zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 24,424
